Rock-Ola CD8 Bubbler C555 Error
Boiler188
by Boiler188 » Fri Jul 17, 2015 11:34 pm
I have a 1994 CD8 Bubbler with the black S-5 Controller. I purchased it from a friend of a friend about 10 months ago. The unit was in good condition other than the lighting and bubblers. I had no problem fixing them and the jukebox has been working great. About two weeks ago, I had it turned on while watching a movie in the same room, but was not playing any CDs. It was more as a mood light.
After the movie I went to turn it off and saw that the CD carousel was rotating continuously. I turned off the jukebox and then turned it back on. It started to go through the normal start-up and flash a series of letters (O, U, C, P, L, A, H) on the Led display. Before it finished the sequence it flashed C, 5, 5, 5 and continued to flash the same characters. I have tried cycling power several times. Sometimes it will make it all the way through the sequence, rotate the carousel one revolution and stop. After about 15 seconds it begins showing the C,5,5,5 again.
I can find no information on Error codes anywhere on the net or any manuals that I can find. Does anyone know what specifically this code means? It would seem like it is a malfunction of the S-5 controller, but I am hoping someone has seen this before.
ds100h
Re: Rock-Ola CD8 Bubbler C555 Error
by ds100h » Sat Jul 18, 2015 5:29 pm
I believe Rockola, Wurlitzer, Rowe and maybe others all made bubblers. It may be helpful to identify the make of bubbler you are referring to.
Check this link, it may answer your question http://www.jukeboxdon.com/#manuals/c20iw
Best
Darrell
by Ron Rich » Sat Jul 18, 2015 6:28 pm
Darrell,
You are correct--almost all juke-makers, made a re-pro, of that model--including "2" "Seeburg" companies, NSM, and I think, Sound Leisure!
However he did ID it , as a CD-8, S-5 controller, black units--which can only be an Antique Apparatus/RockOla, model.
Boiler188
by Boiler188 » Sun Jul 19, 2015 12:38 am
Ron, that is correct. It is an Antique Apparatus / Rock-Ola CD-8. The black controller has a sticker that says S-5 Control Unit and printed on the cover is 56210-2A System 4A Controller.
Users browsing this forum: Google Adsense [Bot], Jimmler, Larry Wilson and 14 guests
It is currently Thu Oct 06, 2016 8:01 pm
