Seeburg m100c stuck
393clevor
Re: Seeburg m100c stuck
by 393clevor » Mon Dec 12, 2011 12:09 am
Ron Rich wrote:You are welcome--And yes,"understanding" is true for me too, and the main reason I wrote the "Seeburg Mechanism Guide".
Unfortunately, I think you are mis-understanding. This problem has nothing to do with the "top area" --
It is the area under the SA Unit, that I believe to be the problem.
Ya after I posted that I did some more reading in the manual and found the contact block to be on the lower back side of the mechanism.. am I correct...
by Ron Rich » Mon Dec 12, 2011 1:25 am
Yep--now that you found it, look at the bracket that "guides" it. The contact block (aka "frog") should be INSIDE the U shaped holder. That holder should have a piece of "spring steel" on the left end that keeps the frog centered. What happens is, if you are lucky, the frog gets knocked out of the holder, and lands "on the bottom of", rather then "beside", that spring. If you are not lucky, one or both of the arms that support the bracket bend, or bust-- Try GENTLY pushing the spring to the left, and "pop" the frog into place. Ron Rich
393clevor
by 393clevor » Wed Dec 14, 2011 8:18 am
I'm going back to work on it tomorrow, I'll take some picture and let you know how I make out with it..
393clevor
by 393clevor » Wed Dec 14, 2011 9:28 pm
YOU DA MAN!!!
The spring was out of place.... I popped it back in and all is well... One question when it has played it's last selection does it hold the last record in the mechanism or should it drop it back into the holder... this one holds it in the Mech until you select another record, then it drops it and moves the next selection.. Also is there a full manual available?
Thanks you so much Steve........
by Ron Rich » Wed Dec 14, 2011 10:12 pm
Steve,
Glad you got it--
A "full Manual" was never published by Seeburg. What they did in those days is have a "Master Manual", to which loose leaf pages were added on a subscription basis, from time to time. Somewhere around the mid-50's, this apparently became somewhat "problematic". so, what they did at that time was to go back, and pick out the pertinent pages for each model, and bind them by model number--however they did not re-paginate it.
Since that time, many "copies" of them have appeared--some well done, others lacking--most notably, the e-versions sold. The "best" are sold by Alwaysjukin Magazine, and Victory Glass--see "where to buy", in the announcements section above.
I wrote the "Seeburg Mechanism Guide as a supplement to the proper model Seeburg Manuals
393clevor
by 393clevor » Wed Dec 14, 2011 11:00 pm
Ron Rich wrote:Steve,
Glad you got it--
So is it normal for the mech to hold the last played record?
by Ron Rich » Thu Dec 15, 2011 6:09 am
If you really want to find that out--do some research, or read the Service Manual--
393clevor
by 393clevor » Thu Dec 15, 2011 7:00 am
Ron Rich wrote:If you really want to find that out--do some research, or read the Service Manual--
OK soooorryyy! I thought you might know off the top of your head... the people that own it have the book so.. hey it works, they can play their music so they are happy happy happy and it's all because of you,,, I can't thank you enough.. Steve
Users browsing this forum: highriverguy and 11 guests
It is currently Thu Oct 06, 2016 9:55 pm
