LPC-480 "hum"
Re: LPC-480 "hum"
by Rob-NYC » Mon May 28, 2012 1:40 am
Dalton, turn the motor shaft with your fingers -make sure machine is unplugged-. You can slightly assist the motion by -gently- turning the turntable flywheel in the same direction but the main force must come from turning the motor.
I agree with Ron re: the relay. This was where we were going before. What may have happened is that during your friend cleaning the contacts he may have pushed them too close together but not gotten all the pitting out. Once power was applied and the motor reversed the contacts sputtered and welded. I have seen this happen on regular reversing switches (the tail on the mech) when someone though they could just bend the blades together instead of properly servicing them.
What happens on the reversing switches is that if one set of contacts don't 'break" before the others make it throws a dead short across the line.
The service outlet is for soldering iron, work light etc.
Eilindrene
Re: LPC-480 "hum"
by Eilindrene » Fri Jun 08, 2012 12:24 am
I adjusted the contacts as the instructions said, and the jukebox is playing records perfectly, both A and B sides. Thank you both very much for your help! Oh, and I noticed a fuse soldered on the mech, could this be an issue in the future?
Dalton
Re: LPC-480 "hum"
by Ron Rich » Fri Jun 08, 2012 5:05 am
Only if blown--which indicates real problems--which must be fixed, prior to replacement-- Ron Rich
It is currently Thu Oct 06, 2016 10:20 pm
