by Ron Rich » Mon Mar 30, 2015 9:24 pm
by mike11 » Mon Mar 30, 2015 9:30 pm
by Ron Rich » Mon Mar 30, 2015 9:39 pm
by Rob-NYC » Wed Apr 01, 2015 2:47 am
by mike11 » Wed Apr 01, 2015 6:59 am
by mike11 » Wed Apr 01, 2015 7:01 am
by mike11 » Wed Apr 01, 2015 7:02 am
by Rob-NYC » Wed Apr 01, 2015 9:29 am
by mike11 » Thu Apr 02, 2015 9:39 pm
Rob-NYC wrote:Mike, sorry for the delay. I think i'm looking at the same tran you ordered and because of the way it was designed and the limitation of the seeburg speaker switch, it looks as though you can wire it for only one types of output at a time.
The internal speaker is 8 ohms, so the diagram at the bottom right on that page shows that black and black-yellow are tied together and for our purposes they will be connected to chassis ground as per the original tran.
Then green and green-yellow are tied together but not connected to anything else.
The output to the speaker is the yellow wire. That wire should be connected to the "20 watt" terminal on the speaker switch since that (IIRC) is also where the feedback wire is connected.
Individually insulate- tape any unconnected wires.
by Rob-NYC » Fri Apr 03, 2015 10:17 am
by mike11 » Fri Apr 03, 2015 7:42 pm
by mike11 » Fri Apr 03, 2015 8:34 pm
by Rob-NYC » Sun Apr 05, 2015 7:52 am
mike11 wrote:It's the white 70v tap off the trans that's left that has me concerned ..... Can that be left floating ??
by mike11 » Sun Apr 05, 2015 8:15 pm
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 10 guests
