Rock ola 484 problems
Re: Rock ola 484 problems
by Ron Rich » Thu Oct 17, 2013 4:51 pm
Daddy,
That's ALWAYS a "lubrication" issue. I suggest that you use only SAE 20 wt, oil on every portion of the gripper assembly. After a total oiling, (be sure to get oil in between the two gears, on the right of the gripper) play BOTH sides of records and gently hold your finger on the gripper while it is picking up a record. One side will start to function correctly first, then do the same thing on the other side--this may take awhile, but I have never found one it won't fix-- also, keep adding oil between the gears. Once both sides are working correctly, play at least 100 selections. Ron Rich
Dealt daddy
by Dealt daddy » Mon Oct 28, 2013 3:13 am
@Ron rich...You hit the nail on the head. We are up and running. Lubrication and cleaning cured this. Thanks again for all the help.
by Ron Rich » Mon Oct 28, 2013 4:53 pm
Hi Daddy,
Glad you "got-it"--now PLAY it, and oil it again in a few daze--- Ron Rich
It is currently Fri Oct 07, 2016 12:30 am
