Problem with DS160 number selection
burnt_finger
Re: Problem with DS160 number selection
by burnt_finger » Tue Oct 06, 2015 3:32 pm
Well there was no continuity from pin 28 to common pin 31 so I took the plug apart and I have some good news and some bad news. The good news is the plug looked brand new when I opened it and all the wiring was good, the bad news is the wiring was good.
I am not sure if I will take the TMU apart yet as I want to enjoy what I have at least for a while before I take it out of commission, If/When I take it apart I will update this thread or I just might buy a different one I am not sure what direction I will go yet.
Thanks for all your help
Brad
by Ron Rich » Tue Oct 06, 2015 3:38 pm
Brad,
Once again--you need not take the TMU apart--yet--didja check the wires at the entrance to the TMU as I described earlier--??
burnt_finger
by burnt_finger » Tue Oct 06, 2015 5:34 pm
Ron,
Yes the TMU was dressed properly (clamped to the mechanism shelf and behind the support post), the clamps where very brittle and I replaced them but it was routed correctly and the TMU wire is in good shape with no kinks in it.
Brad
by Ron Rich » Tue Oct 06, 2015 6:37 pm
Oh, well--into the TMU you must go--I have a spare TMU--missing the ground bar, but good. PM me if you wish to purchase it.
burnt_finger
by burnt_finger » Wed Oct 07, 2015 1:27 am
Rob/Ron
I figured I had nothing to loose so I took the plung and took the TMU apart. The #28 and #31 common where good all the way back to the Number Circuit 8 so I figured the wire going through the torieds was bad connecting the two. So I got into my pinball stock and took apart a hold coil to get the insulated wire I would need and following the Wiring Diagram I ran it through and hooked it up, had continuity from the plug and after getting everything back together it is selecting all locations!!!! :D :D
Thanks For all your guys help
Brad
by Rob-NYC » Wed Oct 07, 2015 7:34 am
Goof news Brad.
You have joined the elite group who have peered into the "great mysterious Tormat"...and survived.
Users browsing this forum: Bing [Bot], Google Adsense [Bot], HorrorBiz 72, Juke-rocks and 10 guests
It is currently Thu Oct 06, 2016 6:14 pm
