by catboxer »
Wed Nov 05, 2014 4:16 am
I took a few days off this project to get fresh eyes on the problem. I've resolved all but one issue. First, I had the wiring incorrect to the frog. I'm not sure how, because I labeled them when I first took them off, but I did. Correcting the wiring restored function to both cancel solenoids. The other issue was the alignment moving. Per Ron's advice, I checked that spring steel and felt it could have been tighter. I adjusted it to hold the frog in place tighter. I also noticed it would move roughly over selected pins on the Even side. Examining that frog pin I noticed it had a small nick or dent in the tip that could have gotten caught on the SA pin. I gently reworked this with fine sandpaper careful not to remove much metal so it would still reach the pin. After these adjustments and corrections I am happy to say it's picking up and canceling all selections on both odd and even sides. Once all selections play, it half-returns the record and stops just as it should.
The remaining issue is that it will NOT cancel selections when there is NO record. The mech continues to scan and play this selection over and over. Reading the manual seems to indicate it will go onto the next selection, which it does, but never actually cancels a missing record. If I load a record, it will play and cancel as normal. Now I don't anticipate having any empty slots, but is this a problem?
Thanks as always!
