by AllSystemsTechCA »
Sat May 14, 2016 3:16 am
I have a Seeburg DS160 that I have spent many hours troubleshooting and perhaps some of my journey will help you. I just got it working today!
The customer complained of the famous "scans twice" problem and I was determined to fix it.
I spent time following the service manual steps and I could not trigger a selection even by applying the 1.5V to the pulse amplifier. This was the first problem.
He had the amplifier previously re-capped but the selection unit and pulse amplifier were un-touched, so I replaced all of those. I also found a bad resistor in the pulse amplifier.
Now at least I could trigger a selection by pulsing the pulse amplifier with 1.5V but still could not do the read-out (applying 1.5V battery to the RCA jack to the Tormat unit).
This is where I had problems still. I found that if I used a bench power supply set to constant-current of 1.5A (the
ideal current to set and read the Tormat) I could actually manually set and read out the Tormat by applying the current between ground and to the rivets of the Tormat, and reversing to read out. So the pulse amp was working, just not the read out still.
I was sure everything was good but now I figured I was not getting enough current to read out. (By this time I had cleaned, adjusted, fiddled with EVERYTHING). I ended up doubling the 0.15uF capacitor which stores the read-out pulse to 0.30uF and sure enough, works like a charm. Still 290V as always, but a stronger pulse.
Best I can figure, the new capacitors I was using just could not supply the current that the old paper capacitor could even though the value was correct.
Hope it helps someone.
By the way, using a 1.5V cell to set the Tormat to all selected (or all de-selected depending on the polarity) still never worked for me. Maybe the batteries I had were just not the same as back in the day. A 1.5A constant current power supply did work.
Sure is an amazing jukebox for the time.
Cheers,
Rubin
