Rockola Capri 2 model 414
Raven65
by Raven65 » Mon Aug 09, 2010 6:16 am
When I make a selection the wiper assembly?, spins around the
Selector wheel? I'm not sure what these are called. That is all that happens. The gripper is at the turntable. The needle arm looks like it stopped halfway through the record. Turntable not spinning. It seems all locked up. Turning off the machine resets selection buttons.
First machine. I'm a total novice. How do I troubleshoot?
Nothing is moving except what I described. Thanks, raven
Re: Rockola Capri 2 model 414
by Ron Rich » Mon Aug 09, 2010 3:24 pm
Raven,
IMHO, the best advise that I can give you, and any "newbie", is to un-plug the phono, and purchase a good copy of the service manual, prior to doing anything else. (SM available from http://www.alwaysjukin.com and other sources)
After READING the service manual, check all fuses to be sure they are the correct size and type. At that point, if you have basic electro/mechanical skills, you will have an understanding as to what has gone wrong, and it is not hard to figure out what needs to be done. Force nothing, as you can do major damage !! Ron Rich
Raven65
by Raven65 » Mon Aug 09, 2010 8:44 pm
Thanks Ron. What's the best way to start learning about ohms, capacitors, valve tubes,etc.
Where do I start checking? Any starter books on how to do this? I appreciate your help. Thanks again, raven
Raven65
by Raven65 » Mon Aug 09, 2010 8:45 pm
I do have the service and parts manual. Raven
by Ron Rich » Tue Aug 10, 2010 6:26 am
Raven,
If you can "self-teach" there are lots of books on the subject, and I suppose today you can "google" most of it--
Also, the old way--school-- Ron Rich
Raven65
by Raven65 » Tue Aug 10, 2010 6:08 pm
School!? That's crazy talk Ron. Seriously, thanks, I'll start digging in.
Raven65
by Raven65 » Fri Aug 13, 2010 5:10 am
What's the best beginner guide on troubleshooting
Thanks. Raven
Raven65
by Raven65 » Sat Aug 14, 2010 2:28 am
Also, are there other model #'s that are basically the same
Machinery as the 414?, so I can start cross referencing
Other posts. Thanks. Raven
Users browsing this forum: Google Adsense [Bot], Juke-rocks and 13 guests
It is currently Thu Oct 06, 2016 6:32 pm
