Rock-Ola 425 gripper motor - rebuild?
CoindoorDave
by CoindoorDave » Mon Aug 05, 2013 2:39 pm
So I've got the gripper motor removed, and have cleaned up the drive shaft, cams, gripper arm and assembly so it once again operates poroperly (was seized up - detailed in another post).
Question: Aside from cleaning and maybe oiling the gripper motor, does it need anything else before being reinstalled? My brother, a vetereran of small engine repair mentioned opening it, cleaning the inside and packing it with new lithium grease since it is 40 some years old. Should I or should I test it as-is first?
CoindoorDave
Bettendorf, Iowa
AMI-ROWE R-81 (Orange Pulsar)
Re: Rock-Ola 425 gripper motor - rebuild?
by ami-man » Mon Aug 05, 2013 5:24 pm
Hello CoindoorDave,
I would agree with your brother and strip it down.
by Ron Rich » Mon Aug 05, 2013 5:27 pm
Hi Dave,
I would surley open the gear box, to check the condition of the grease. If still "plyable", I woud just spread it around as needed. If hard, it does need replacing--One caution must be observed: Either ALL old grease must be removed, or the new grease must be able to "combine" with the old. I don't like "lithium" grease--I much prefer a graphite based item. "CRC StayLube Moly Coat Hi Pressure" brand is what I use. Ron Rich
CoindoorDave
by CoindoorDave » Wed Aug 07, 2013 1:36 am
OK - best way to clean out these oreo cookie crumbs? :o Mineral spirits? Tough Stuff foaming cleaner? Sand blasting? :)
CoindoorDave
Bettendorf, Iowa
CoindoorDave
by CoindoorDave » Wed Aug 07, 2013 2:05 am
OK, so I got the motor out, and out fell 4 brass washers, 1 steel washer, and 1 washer of some fiber type material. Also, curiously, in addition to the two brushes & springs on either side in the bottom, a third spring (with about 1mm of a brush left) fell out (a spare from a previous repair?)
How are the washers layered (above/below brushes?) Looks like 2 or 3 go on top (looking at the pic above)...
CoindoorDave
Bettendorf, Iowa
by Ron Rich » Wed Aug 07, 2013 4:55 am
Dave,
" The best way" to clean those cookie crumbs is Di-no-mite----one "poof" and they'z gone !
I use a solvent bath and a stiff brush.
As for the washers?? I think, they were assembled with the fiber washer in the center of the two metal ones---Ron Rich
CoindoorDave
by CoindoorDave » Wed Aug 07, 2013 1:26 pm
Am I correct in assuming that there should just be the two brushes (near the screw holes on either side near the bottom)? A third (mostly a third spring, what little bit was at the end of the spring would not have made an effective brush...it was just rattling around inside near the bottom).
Cleaning it out (will post pics later). Thanks.
CoindoorDave
Bettendorf, Iowa
by Ron Rich » Wed Aug 07, 2013 6:17 pm
Dave,
Yes--You'z correct !!
CoindoorDave
by CoindoorDave » Thu Aug 08, 2013 3:43 am
Question: after I finish cleaning and re-lubing the motor, what is the order/sequence that these washers go on? There are four brass, one steel (the same size as the brass ones), a slightly larger metal on (a bit concave) and a fiber one that appears to have a faint scoring where the larger metal washer went.
CoindoorDave
Bettendorf, Iowa
eguy-harley
by eguy-harley » Tue Sep 23, 2014 4:49 pm
Is it possible to remove the motors with the unit open and not having to mess with the gear box? i.e. Can I leave the gear box and pull the motor away? Or do I have to remove the gearboxes too? I'm hoping that I can clean the motors without having to take the whole thing apart.
by Ron Rich » Tue Sep 23, 2014 4:58 pm
"Possible"--I would guess, "Maybe"--depending on where the motor is in relation to the outside of the cabinet--However, I would not attempt this--Motors are easy to remove--Un-plug, then remove the three bolts holding the motor in place--When returning them allow a very SMALL amount of "gear lash"--
Users browsing this forum: Google Adsense [Bot] and 13 guests
It is currently Thu Oct 06, 2016 6:25 pm
