Seeburg USC1 Questions
ds100h
Re: Seeburg USC1 Questions
by ds100h » Sat Oct 20, 2012 9:53 pm
Found 311125 Power Supply Board Assembly in Digital Control Center Type DCCI, Code B in the manual. Now I need to locate the reset transistor. Also, your book arrived in today’s mail. Will see if I can find anything in the book about “timing”. I know how to time a car, but I have never "timed" a component in a Juke Box :oops:
Best
Darrell
by Ron Rich » Sun Oct 21, 2012 3:37 am
Darrell,
Thanks for buying the book-- do not stay up too late, reading it, tonight-- :lol:
ds100h
by ds100h » Mon Oct 22, 2012 3:36 am
Ron
Your welcome. Up all night reading and never did find anything on timing?????
I did notice info about lamps need to be 1819. In checking this I found 4 empty sockets, 1 socket with an 1819 lamp and 2 sockekts with 1614 lamps.
Will replace missing bulbs and improper bulbs with 1919 bulbs.
Best
Darrell
ds100h
by ds100h » Mon Oct 22, 2012 3:38 am
oops I mean 1819 lamps :D
by Ron Rich » Mon Oct 22, 2012 4:46 pm
Darrell,
See paragraph # 5, page 21---
ds100h
by ds100h » Tue Oct 23, 2012 3:32 am
See what happens when you stay up to late and don't where your glasses! I do not have an analog meter so will need to wait for Mark to stop over with his to check "timing".
Darrell
ds100h
by ds100h » Tue Oct 23, 2012 3:33 am
FYI I do know it is "wear" and not "where"!
by Ron Rich » Tue Oct 23, 2012 5:43 pm
Darrell,
You know you can edit out errors easy--just click on the edit button and make your changes, without adding a new post----I do so all the time-- :roll:
ds100h
by ds100h » Sat Oct 27, 2012 3:35 am
Thanks for the tip, most boards do not allow you to edit an old post.
My manual has a DCC1, Code B. Looking at the actual Juke Box, it has a DDC3 Code B installed in it. I do not have a schemtic of the DDCw, Code B.
Is there any concern about the difference between a DDC1 and DDC3 that I should be aware of in making these tests?
Thank you
Darrell
by Ron Rich » Sat Oct 27, 2012 4:34 am
Darrell,
Once again, I will encourage you to stop "messing with" the phono, sit down, and read your copy of the Microlog Trouble Shooting Guide--
ds100h
by ds100h » Thu Nov 01, 2012 1:42 am
Ron
In reading your manual, it says SHP & TSA amps are interchangeable to "some degree".
My Seeburg USC1 has a SHP1 Code B Amp installed instead of the TSA10 Amp listed in the Seeburg Manual. Obviouly, I also have no schematic for the SHP1 Code B Amp.
Any words of wisdom on anything I can do to protect the phono since this interchange is not recommended?
Thank you
Darrell
by Ron Rich » Thu Nov 01, 2012 5:43 pm
Darrell,
It was not recommended due to thermal problems. The heatsinks on the the TSA vs. the SHP, are mounted differently, and the SHP's, if used in USC phono's, tend to overheat. If I were to leave a SHP in a USC phono, I think I would drill a series of small vent holes in the cabinet rear wall to allow the heat to escape--and maybe some lower ones to allow fresh air in ? (Don't recall offhand what the air "intake" looks like in that model) Ron Rich
ds100h
by ds100h » Thu Nov 01, 2012 9:50 pm
Ron
I shall plan on drilling some ventialtion holes. top & bottom for air flow. In process of doing "D" cell batery test and checking voltages.
Thank you
Darrell
mb9513
by mb9513 » Thu Nov 08, 2012 7:12 am
Hi all. I am having a problem checking the -27 volts coming to the dtp1. the manual shows that pin 4 on connector j3700 should be live coming frim the DCC1. and pin 5 shold have the same voltage for the panel lamps. i get the correct voltage on pin 5 and not 4. It is almost like the pins are reversed. Is the manual correct?
It also also shows that the -27 passes through from one pin to the other. so i am not sure if this has damaged the dtp1. I am at a loss as to what is happening. we have no credits at all. there is no way to get a good write in, the read is fine we did the battery test and the tormat works great. Thanks in advance. Mark
by Ron Rich » Thu Nov 08, 2012 7:09 pm
Mark,
You are not reading the print correctly--notice the -27 vdc source has a "SW" showing ? That stands for "switched"--is the "switch" on ? If you have -27 on pin 4, the "more coins" lamp should be lit--?? Do you have the correct lamps installed in that section--it is necessary to use, ONLY, # 1819 "double hung" lamps in this section. Are the resistors next to the lamps good ?
The "switch", BTW, is located in the DRIT--, if you have that unit installed, or by a "dummy plug" which should be plugged into the DRIT's socket down to the right of the service switch package, on that model phono.
Users browsing this forum: Bing [Bot], Yahoo [Bot] and 13 guests
It is currently Thu Oct 06, 2016 10:57 pm
