Seeburg L100 -Trials and Tribulations w/the Cancel Solenoid
Re: Seeburg L100 -Trials and Tribulations w/the Cancel Solen
by Ron Rich » Wed Jul 17, 2013 4:32 am
OK--take a photo of the coil stop--inside--and be sure to re-adjust the coil position according to specs.
Adonnis
by Adonnis » Wed Jul 17, 2013 4:41 am
Ron - That is the coil stop on the lower right-hand corner.
It's the plate that covers the end of the coil winding.
by Ron Rich » Wed Jul 17, 2013 4:44 am
I do not see the stop--I see the plunger and the coil, and the front "coil frame", but not the rear one--
Adonnis
by Adonnis » Wed Jul 17, 2013 4:47 am
Top Bracket goes over the solenoid, the bottom bracket goes on the bottom end.
The cup is concaved to the shape of the plunger.
Adonnis
by Adonnis » Wed Jul 17, 2013 4:50 am
Perhaps a bad picture? Can you see the two frames on the right side. One has a hole for the plunger to go through. The other a plug.
by Ron Rich » Wed Jul 17, 2013 4:52 am
Nope--only part of the one with the hole--
by Ron Rich » Wed Jul 17, 2013 4:54 am
somehow my earlier post did not post--
I need to see inside the stop, to see what the brass portion looks like--if bad--plunger will "hang"--
Adonnis
by Adonnis » Wed Jul 17, 2013 4:56 am
Sorry...
Maybe this one...
by Ron Rich » Wed Jul 17, 2013 4:58 am
Yes--that's it--but it looks OK ??
In which case, I am out of answers :(
by Ron Rich » Wed Jul 17, 2013 5:00 am
One other thought --did you "read" all contacts with an analog, NOT digital, meter ?
Adonnis
by Adonnis » Wed Jul 17, 2013 5:04 am
It does look okay doesn't it, and it's clean inside.
Well.... I've only one thing left to try.
I'm going to lengthen the spring up a bit to lighten the pull on the timing relay.
I'm thinking that the coil might be a bit weak. I don't have any weights to push down on it.
To answer your question.... why in the world did I throw away my old Simpson 260? lol
And no, I'm using a Fluke DVM.
Adonnis
by Adonnis » Wed Jul 17, 2013 5:15 am
Well, if that isn't interesting.
It's working now.
At first there was a 1-2 second buzz before the buttons popped, and then it quit all together.
I was trying not to mess with the spring, but giving it a little stretch seems to have worked.
Or, it was a combination of a couple of things I did tonight, along with that.
It would seem I was on the edge of getting it....
Thanks Ron!
I'll cross my fingers. I'll let it cool off, and fire it up tomorrow.
Adonnis
by Adonnis » Thu Jul 18, 2013 10:32 pm
Working!
Now to fine tune those snap, crackles, and pops when the carrier is searching for the record selection.
by Ron Rich » Thu Jul 18, 2013 11:29 pm
Glad you gottit!
For "poping"---
Check the mechanism wiring--look at the terminal strip on the front left--Starting from the BOTTOM, count up to number 5. If there is not a 2 watt resistor there--let me know--check the ground screw tightness (terminal # 1).
Check the detent switch, for dirty/burned , pitted contacts. Also check gap, and wipe-- set as per manual--check the contact plungers, for "flatness" and silver left-- and alignment, as per manual.
Then look at your AVC board--Check C-171--it should be a .22x400. Check R-186--it should be a 6.8meg.
Check the power amp board schematic/board itself. Find test point # J-257 and R-263 (10 meg). Once located, see if there is a 10k between the 10 meg and pin 7 of the 12AX-7 tube. If not, cut the trace, and bridge the cut with the 10 K.
If all of the avove is correct, the poping will dis-appear !
Adonnis
by Adonnis » Mon Jul 22, 2013 3:04 am
Ron;
Yes, on the 2-watt resistor, it's a 2.2Kohm one.
Yes, on the tightness of the ground screw.
The detent switch was mighty filthy. I didn't know that guy was back there. Cleaned it.
Not easy! That was a hard one to reach. lol
AVC board, check.
Power Amp Board - nope, no 10K resistor between pin 7 of 12AX7 and the 10Mohm resistor.
Will locate a resistor tomorrow.
-Put in the resistor, still crackling.
I noticed that the unit had no ground wire. I've since added one, and ran a ground wire to the metal frame, and up to the carriage.
Users browsing this forum: Bing [Bot], Yahoo [Bot] and 12 guests
It is currently Thu Oct 06, 2016 10:56 pm
