Seeburg M100C
Re: Seeburg M100C
by Ron Rich » Fri Oct 25, 2013 5:26 pm
I don't understand how you can miss it--it is right above marked- "Used, new parts/"Books"/ Repairs--where to find- Do you have the Maintance Manual ( also called an I & O Maual) for that model ? It will show you the "blackhead" cartridge--those are rebuildable. Ron Rich
ultraliter
Re: Seeburg M100C
by ultraliter » Fri Oct 25, 2013 8:52 pm
This is what my cartridge looks like and this is what I am seeing at the top of my page.
(497.38 KiB) Not downloaded yet
(379.8 KiB) Not downloaded yet
Ken Layton
Re: Seeburg M100C
by Ken Layton » Fri Oct 25, 2013 10:25 pm
Here is what you should be seeing on the jukebox forum's index page.
phonoland index page.JPG (163.27 KiB) Viewed 997 times
Re: Seeburg M100C
by Ron Rich » Fri Oct 25, 2013 10:43 pm
Click on "Board index"--go to the jukebox section, and you will see it--
You have an aftermarket "Thorpe" cartridge in that phono-- Ron Rich
ultraliter
Re: Seeburg M100C
by ultraliter » Sun Nov 03, 2013 7:24 pm
I have replaced the cartridge with a new one with new needles and one side still does not play good. The music is garbled. The other side sounds fine. I have a MRA4-L6 AMP that has not been rebuilt.
Bob
Re: Seeburg M100C
by Ron Rich » Sun Nov 03, 2013 8:16 pm
Bob,
The only difference in sides is the tone arm pressure, and how wire "follows". Check that it is free, and not "shorting" out somewhere on the "bad side". The amp, tho it should be rebuilt, can not distinguish the side that's playing
What type cart is now installed ? Which needles, at what pressure ?
ultraliter
Re: Seeburg M100C
by ultraliter » Sun Nov 03, 2013 8:33 pm
I just replaced the Thorpe Grey and White with a Vern Tisdale Cartridge and needles.
Bob
Re: Seeburg M100C
by Ron Rich » Mon Nov 04, 2013 3:48 am
Bob,
That's half of the answer--what are the needle pressures ?
ultraliter
Re: Seeburg M100C
by ultraliter » Mon Nov 04, 2013 2:49 pm
I do not have a gauge to check or set pressure. Can it be done without it? If not where can I get a gauge? I just discovered something else, when the record is turning clockwise, looking at the right side, it is fine but when it is turning counterclockwise it makes a ticking sound. Is there any chance the motor is running slower in one direction?
Bob
Re: Seeburg M100C
by Ron Rich » Mon Nov 04, 2013 6:06 pm
Bob,
I believe any of the suppliers listed above have needle pressure gauges for sale--It can be done, but it takes LOTZA practice---
The "clicking" sound usually indicates lack of,or improper oil in the mechanism--doubt the motor speed is slower-- Ron Rich
ultraliter
Re: Seeburg M100C
by ultraliter » Fri Nov 08, 2013 8:41 pm
I have a needle pressure gauge coming. How much pressure should there be?
Bob
Re: Seeburg M100C
by Ron Rich » Sat Nov 09, 2013 3:08 am
Bob,
That info, and a good drawing, with "adjustment procedure" is in your service manual--
reddfam
Re: Seeburg M100C
by reddfam » Tue Nov 19, 2013 7:24 pm
Hello, new to the forum, but wanted to get back to the wiring for the M100C motor start capacitor. Understood the wiring colors are not consistent. Not that I'm sure it helps, but the motor housing cover has "March 1952" stamped inside.
The wires leading to the old motor start capacitor are black, green, and what appears to be "off" yellow or faded orange. Not sure If the latter is really old, grimy, oil stained white. But, since I've seen references to yellow wires showing up in these, thought I'd throw the query here. 1.4 to ?, common to ?, and 1.0 to ?
This machine is a basement estate sale find. It's like a time capsule. All original, pretty complete--missing the light diffuser, lamp and starter for the fluorescent behind the selection trays (now replaced) and has the chrome pilasters, hence no animation gear. Also has 11 of the original 12 glass tubes, in very nice shape.
Before I bought it, the owners fired it up and it selected and played a 45, speed good at start, slowed, then back up to speed. Figure that is probably a combination of dried lubrication and, possibly, the motor start capacitor. Did not hear any hum or crackling when it was run. Has a new (according to owners) Seeburg red cartridge in it (also has an envelope with the old one, plus another that has one of the two connection pins broken off--any way or point to fixing it?)
Have not run it since then, slowly cleaning and lubing it up. Checking tubes--has three Seeburgs that check out as good on my tube tester.
History of the unit--Prev Owner was a musician. Played a bar in PA ('70's??). Jukebox was not working in said bar. Bar owner sold it to the guy for $5. Somehow put it in the back of his old convertible (what a sight!) and got it home. Over time, he had someone get it working (not sure what that required). Finish on the case is like a fine "spatter paint" wall paper--absolutely looks old, if not original. It's in pretty good shape, with expected wear.
Anyway, looking for the wiring answer. Thanks!
Re: Seeburg M100C
by Ron Rich » Tue Nov 19, 2013 9:28 pm
According to the service manual (please see "Atten Newbies" above !!) the 1.4 goes to the "O" contact the C to the upper left motor contact on the four position "tie strip"--and the 1.0 goes to the upper right side of that same tie strip. Ron Rich
Users browsing this forum: Jimmler and 13 guests
It is currently Thu Oct 06, 2016 11:07 pm
