Accessory input board for a Rowe R-84?
Re: Accessory input board for a Rowe R-84?
by Ron Rich » Thu Jun 03, 2010 7:39 pm
Hi All,
While it's true that the "late style" (red, belt driven) 45 rpm motors have no "oil wick", it just goes against my way of thinking that a steel shaft can run in a "brass bearing" very long with out oil. I have in fact, needed to replace several of those motors due to that bearing being "egg shaped". Therefore, I oil every one of them--just "squirt" them under the drive hub with 20 wt ND oil.
The transfer motors used in at least, the later style 45 rpm units, and all the CD units do have two large oil felts ! Rowe had "oil problems" with the early CD100's and developed an "oil shield" to add to the motors that prevented them from "splashing oil" onto the CD's. Rowe claimed that the motor manufg. was "over oiling" them--but they added the shield to all production units, and came out with an add on kit, for the older ones, anyway---(at "NO Charge" !!)
The sprag motor has at least one oil felt--maybe two--I can't recall, nor can I find my spare motor---I think that there were two suppliers (or "versions") for these, and maybe only one of them had the two felts? Ron Rich
Andy J
by Andy J » Sat Jun 05, 2010 12:30 am
Thank you all for your input. I have decided to order the chipset for the CCC. I'll keep you all informes as to my thoughts on it as soon as I get it installed and tested. I'm also still hunting for title rack number strips... Someone tried to paint the racks in mine....poorly! I found a set of racks from an R-74, and as you know they use a letter/number combo, not 3 digit numbers like my 84.It's got me going crazy... I've tried to make my own, but it's just not working out...can't seem to get the spacing correct..Tearing.....out.....what....little....hair....I....have.....left!!They seem to reproduce everything else, why not these?
Thank you all again!
Andy
by ami-man » Mon Jun 07, 2010 11:19 am
Hi Andy,
Try looking for R-80S, R-81, R-85 and CTI-2 title racks all can be used on your jukebox.
Andy J
by Andy J » Thu Jun 10, 2010 6:43 am
Thank you all very much.I really appreciate your help!
Andy J
Users browsing this forum: Google Adsense [Bot], Juke-rocks, Yahoo [Bot] and 10 guests
It is currently Thu Oct 06, 2016 2:13 pm
